Went out today to check on the cars, and there are a number of very black oily puddles along side the MaggotWaggon where I park outside. Usually, SWMBO takes that spot, and I noticed the puddles yesterday under her car, but thought it was just rainwater (it was dusk at the time). Well, I look under the hood, no leaks, no drips, no errors, yet the rightfront wheelwell is just coated with oil and grease! The puddles must be coming from rainwater splashing up there and washing the grease off. What the #$&?? I pull it into the garage, jack it up, and remove the tire. No obvious leaks on the underside of the engine, nor anywhere else. I see similar, but less severe, oil and grease on the right rear; none on the left sides. Brake lines aren't leaking. I cleaned it all up with SimpleGreen, and will keep an eye on it. Yes, we have big puddles from rain around here, but why only on the right side?
When the Exploder comes home, I'll inspect it as well. This is wierd.
http://clubs.hemmings.com/baymustang/platesmall.jpgLet me check your shorts! My multimeter is just a-waiting! Formerly known as Midlife in the old VMF.
King of the Old Farts *struts*
