1 - 2 of 2 Posts
My login only takes me to the new forum but post me here. Is it only the vavle which could create a ticking noise. And would I be able to tell if it was coming from above or below??
MJS
I can only tell you what the ticking noise turned out to be on my '69 Mach. My mechanic took off the timing chain cover and discovered a piece of metal sticking out. Main bearings shot. Overhaul time. Mechanic said, "And it was running so well...." Hope this doesn't apply to your situation.
Good luck,
Val
1 - 2 of 2 Posts
