I have a 1969 Mach 1 S code i went to cut the car off and it would not cut off. I had to turn the switch all the way to ACC to kill the motor. I assume this may a switch problem. I would really appreciate and other thoughts as to what this might be. This is the first time this has happened. Thanks
Unless the switch is spinning in the hole, so off is now where acc should be, yeah.
Unless it is spinning and I cant feel it. I mean it seems to be switching OK. I guess i will put a new switch on and see and go from there.
for a second in my car after i reinstalled the wiring because of engine rebuild i had the problem of car starting in ON position but i fixed that. chances are that you need a new ignition switch.
