OK, I got everything wired up ... not permanent just a test fit to see if I should go the distance with this thing and neaten the wiring etc.
For those who recall I was looking for a small, easy add on to put a little umph in the low end on my sound system. Not shake the ground powerful, just a nice little hum in the seat backs and your belly ;)
So I ordered up the Infinity Basslink for around $215 + shipping from an online vendor. I won't give them any free publicity since they were not very good about shipping quickly or even knowing where my order was and its status.
I placed this thing in the trunk on the driver's side trunk floor, fits in there well dimensionally but I will have to craft some mounting brackets since the base is wider than this area of the trunk floor.
So far I have tried it with the top up and the car running and not running. I will say it appears to be worth the $250 or so total investment. It is noticeable at all volume levels and adds enough to justify the expense. Granted I am not doing backflips here or anything but it seems like an ok value for the money.
Down the road of course I will get serious about all this and have the trunk fully glassed with amp racks etc. and serious sound setup, but for now this is fine.
it wound vibrate the car apart, i had 2 10" kenwoods in my 69 when i was going to high school, stuff rattled yes, but thats only b/c i didnt put my rear speakers in great, other then that it worked great and sounded good too. best part was, you couldnt hear them outside of my car b/c the mufflers hid the bass :).
I love my basslink!!! It fits very neatly under the quaterpanel behind the wheelwell and it sounds great in my vert. It's given my mustang a nice sound without going stupid with it.
Jay, Have you got the dimensions on it. Do you think it would fit against the seatback inside a coupe's trunk?
SWMBO wants more bass. Sounds like I could be a hero on the cheap ::
Dan
Discussion Starter · #7 ·
Yes I believe it would fit there, but based on the design of it where I mounted it is the optimal spot since it is designed for "corner loading" and plays off that area best.
