On the '65, there is a big difference between the 6-cyl and V8 center link. The V8 tie rods are mounted closer to center and 90º different from the 6-cyl. From center to center between inner tie rods pivots across the 6-cyl center link, the dimension is roughly 23". Does anyone know this dimension on the V8 manual setup?
Thanks,
Al
What are you up to Al? Give me a few months, and you can come over and measure for yourself... ;)
Slade
Well, I've got this Escort rack and took the inner tie rods off and disassembled. I welded on small plates to the tie rod nut, screwed them back onto the rack and punched holes in them in the same location as the 6-cyl center link inner tie rod pivot points. However, I am now converting to V8 spindles and need to make changes to what I've already done to keep the geometry with the spindles.
Al
