I'm about to install the wiper assembly and heat/AC in my 1967 shell. Which should go in first, or does it matter? I want to get this right the first time, because laying on my back in the floor is no fun working at my age.
Install the wiper assembly, then the heater box and defrost plenum, DEFINITELY.
After the wiper assembly, run the A/C compressor wire and the 2 vacuum hoses through the firewall, then the defroster ducting, then position the fan housing with the dash duct over the trans tunnel and then the evap box up behind the glove box. Wiggle things around until the fan housing is solidly mated to the evap box.and lift the assemblyinto palce and secure to the firewall. The rest of the vacuum hoses and the air ducts now and you are nearly finished with the under dash part of the assembly.
Wisdom comes with age. I found it infinately easier to remove the front seats whenever I have to work under the dash.
Discussion Starter · #5 ·
Fortunately or unfortunately, (depending on how you look at it) The car doesn't have seats, yet. I looked at a pair of '86 Mustang GT seats, but the frames were in bad shape, or a set of custom made Cerullo's. The price would be about the same, figuring repairs and new upholstery on the Mustang seats.
