I installed the new turn signal switch, and the car still has NO TURN SIGNALS! What now? Ive checked everything I can think of.
These guys blow out realy easily, as the base that they sit on is ground, and the rivet heads on the back of the turn signal switch can easily short. I put black electrical tape on the back side of the switch as insulation.
I suggest you get a volt meter and a good schematic (If you don't already have them) and trace the voltage path to the turn signals.
I'd start at the switch harness and see if you have voltage going to the switch first.
