1 - 2 of 2 Posts
I'm finally getting around to installing my tach cluster. The one I bought came out of a '68. I need some help cause when it comes to electrical, I'm sunk. Do I use the my old cluster out of my '67 for the '68? A lot of the connectors are different. Also, where do the two wires from the tach go? Can I splice into something? Thanks, Rich
Dude I hate to break it to you but 67 and 68 dash wiring are different. It can be done, but you will need to remove the wiring harness from the back of your 67 dash and install it onto the 68 tach dash. This however will still not fix everything as the wiring harness is a little different to for a tach dash. I know how to do it, it has been a long time, but I really not sure that I can explain it all here. I am thinking that someone has a webpage set up for that, maybe. :: good luck fd
1 - 2 of 2 Posts
