The ground from the instrument cluster etc is intermittently loose, or power to the instrument and radio circuits at the fuse box are either loose or corroded, is my guess.
The ammeter gauges are famous for not working or barely moving and are often burned on inside, and require ALL grounds to be clean.
Your fuel gauge not working before is a problem with current to the gauge, or between it and the sending unit and its necessary ground, or just a crap sending unit, but it won't work reliably until you fix problem one.
