Also consider a vintage Cobra or Edelbrock F4B.....but a Performer will work fine.
I made a 1/2" phenolic spacer with a PCV bung for the Cobra manifold on my D-coder...I prefer PCV and having it spread amongst all the runners from a central location like a spacer. Plumbing it to the carb baseplate, if such a port exists, is fine too. My 4100 didn't have one.
For me, on a stock engine, the main reasons for having a spacer is to facilitate PCV hookup and to mitigate heat-soaking the carb, due to the faster heat transfer of the aluminum intake. Cool fuel is a good thing (relatively speaking *G*)...that's why you may have seen buckets of ice (cool cans) on race car fuel systems in the past (I had one on my street racer; filled it up with dry ice every weekend *G*)
Figure about 10-12 hp from the manifold change; maybe a bit more, depending on your compression ratio and efficiency of the exhaust beyond the tri-y's...
Good luck!
