The threaded hole for the 90deg water neck is much larger on my aftermarket intake than the original. What is everyone else using in this case? Was planning on sizing it up locally but then I see the original extends down into the intake a bit and didn't know if that is necessary or not *see pic of original. If I can use a standard 90deg elbow from local store that would be ideal.
Hi, how ya doin
I used a brass fitting like Asm109 linked to above in my Edelbrock Performer RPM manifold.
Yes, an easy peasy hardware store pipe bushing.
Orielys has the proper size nipple. I try and stay away from extra hardware, its just more possible leak points.
