I guess I should have investigated a little more.... Since I don't really plan on any real showing of my car when its done. I'm going more of a restomod direction on my 68 vert... I decided that I was going to kinda two-tone my interior along with the deluxe panels etc.(68 interior not as fancy as previous yrs) I'm going Candy apple red on the ouitside so I thought black seats, dash pad, door panels with a red (metal) dash , console, and dye part of the inserts on the deluxe door panels. give kind of a wrap around effect. Wanted kind've of a red red..... check all the suppliers sales books and they listed "Dark Red". OK.... so I decided I'd stick with correct colors for 68. supplier #1 sends paint....dark red.( I had bought a restored steering wheel paint doesn't match wheel,I assume they used wrong color on wheel) I go ahead and paint column, glove box etc. when doing dash ,had a few areas that wanted to lift... ok..... had some stuff to get from supplier #2 so order some more paint to redo dash..... different color! What! this one has far more metallic in it! Ok I'll just get more. had stuff to get from supplier #3 Order paint also.... ( you can guess whats coming) wrong! Low and behold paint gets here and it's Red.... the Red I had in mind to begin with..( matches Steering wheel).. Anyway..... Where there 3 different Reds available in 68 for interior colors? This is getting funny now and I have nothing better to do than repaint everything again! Anybody Know the correct color for 68 ..... Red......Dark Red.... Both?
Ken
99 GTP
97 Yukon
68 GT convert
Just looked at NPD's Catalog, they list 2 reds. Have to check my shop book at lunch. If no answers by then, I'll post back.
1966 Red Conv (200)
1966 White Pony Int.(289)A Code
1966 Coupe (289) C Code
MCA 36048
This is what I found for 1968:
Group 1, factory trim code 2D 5D 6D,7D,8D,9D all use Dark Red Irid R/M #5792R
Group 2, factory trim code 2D 5D 6D,7D,8D,9D all use Dark Red Irid R/M #5732R
Group 3 factory trim code 2D 5D 6D,7D,8D,9D all use Dark Red R/M #5732R
Difference between group 2 & 3 ? same paint number different description????
1966 Red Conv (200)
MCA 36048
Discussion Starter · #4 ·
Hmmm... the whole thing has me a little baffled.... Mustangs unlimited doesn't even show "Dark Red" all they list is Red? the 1st paint I used had little if any metallic and the second one lots of metallic so much so the color was 1-2 shades lighter..... If these suppliers don't know what there doing how are we suppose ta match anything up? Thanks for your help! I'm not sure what to do now?
Ken
