The shop that will be repainting my Mach 1 this winter has said that if I pull the engine he will detail my engine compartment for 250. It will not have all the correct decals but other than that it will look new. I plan on doing an engine swap in the spring anyway so pulling the cleveland is not an issue for me. Is that a fair price?
Depends on what he means by "detail". Is that just shooting the engine compartment? Is it pulling out hinges, springs, radiator, yatta, yatta, yatta and cleaning up/refinishing them as well?
I'd want a detailed description of what I was getting for $250.
It's a pretty easy task once the engine is removed. I'd do it myself. I'm sure he won't go into as much detail as you would, and you will no doubt be disappointed with his results. It's not hard, just a bit time consuming. How much time do you think he will spend on it for $250, including supplies? Just my $0.02.....
Banned
That's an average price. Our shop charges $350 to $750 depending on how much detail is involved. For $350 the engine stays in, and we detail around it or the customer pulls the engine prior to giving to us. We degrease, sand and re-paint the bay. If engine is left in, we also degrease the engine, tear it down partly such as carb, power steering pump & a/c compressor, etc. and repaint engine as well, including the p/s pump and a/c compressor, etc. No decals and not concours, but looks good for the local car shows and such. The $750 gets the royal treatment such as nuts & bolts, hinges, etc, done correctly or exactly how customer wants it, and of course decals! ;)
So see exactly what he covers for $250, degreasing and sanding is important if you want it to last longer than a season.
If u plan on pulling the engine in the spring, why don't you just clean it up yourself? It's not that hard of a job.
I can't see how you can get much detail for 250.00. A real detailing is a major task if done properly ::.....Billy
to properly detail an engine compartment, in my opinion, requires removing all the old crud AND paint and LOTS of prep before shooting one ounce of paint. To get the engine compartment below in its current state required many, many hours PLUS lots of hard work - I personally don't think you would be satisfied with a 250 "quickie" job. Its no problem at all once you pull the engine and front end sheet metal parts to jump right in there and tackle the job - just lots of sweat and determination.....
randy
http://www.bossman-motorsports.com/engcomp1.jpg
Discussion Starter #8
The job he will do is degrease, sand, and spray.
