i have to add brake fluid daily or there is no stoppin'. is there anyway to tell where the leak might be by the way the car acts? the car isn't here to inspect presently. jes wonderin'.
Discussion Starter · #2 ·
Have you considered the 55 gallon drum size
You could roof mount it and have a drip feed to the master cylinder thereby eliminating a daily check of the fluid level and save a buck or two
Having fun Bishir?
Greg B
I think GM made the special 55 gal. drum bracket holder for the Vega.
James
1965 convertible "White Pony", my own lesson in mechanical humility
1968 coupe "Jedstang" for the soon to be 16 y/o boy
If it has power brakes and has no obvious leaks in the wheel cylinders and/or lines, you may be leaking behind the master cylinder. The engine will suck it up and pass it through. I had the same problem a long time ago - also had a transmission leak that did not leak to the ground - I found that the vacuum modulator valve was leaking and getting sucked up by the engine too - these fluids will burn somewhat, and you may never notice the engine running differenty. Hope this [email protected]
1966 Candyapple red - A code ragtop
