That's all I need for my 289 to be a 302? is it really that little?A 302 crankshaft and connecting rods are needed. Pistons are the same.
Yep.That's all I need for my 289 to be a 302? is it really that little?
Yes, it is only 13.That's all I need for my 289 to be a 302? is it really that little?
I plan to make my original 289 into a 331 stroker one day 😄 It has never been bored over and it a ‘normal’ everyday Mustang with a matching VIN on the block (1968).What's the fixation on the 302? The 289 is a very capable motor. A 302 is a variant of a 289! If your gonna spend money on a crank, rods and machine work. Why not just go 331 or 347?
Sure it does. It could be for all the wrongs reasons and misunderstandings of what he’d be gaining. There have been a lot of times I have ended up not doing something because my reasons for wanting to do so were wrong.It doesn’t matter WHY the op wants to go from 289 to 302. He can if that’s his desire. Question asked and answered. Good luck with your quest!
A 302 only has 4.5% more displacement. Compression would go up less than a half point.289 heads have smaller combustion chambers than a 302. If you run 289 heads with 302 crank and rods you will significantly increase the static compression.
It’s that easy, plus you need new emblems for your fenders and a sticker for your breather cover. It’s not nice to fool people….
yea thats what I am shooting for now, a 347, just trying to get a decent build from itWhat's the fixation on the 302? The 289 is a very capable motor. A 302 is a variant of a 289! If your gonna spend money on a crank, rods and machine work. Why not just go 331 or 347?
oh ok, so better just to shoot higher. A 347 is what I have been eyeing.302 and 289 use the exact same block, cam, pistons, valve train, tin….just crank and rods are different. You’re just not gaining much going from a 289 to 302 for the cost involved, so I don’t understand the motivation. 289, 302, 5.0 are all variants of each other.
I will not lie, it is because of misunderstanding, I thought I was much more limited on what I could do, but after learning I can make a 347 from it that has my attention much more.Sure it does. It could be for all the wrongs reasons and misunderstandings of what he’d be gaining. There have been a lot of times I have ended up not doing something because my reasons for wanting to do so were wrong.
