I'm replacing my original York compressor with a Sanden compressor on my '66 A code GT. The old compressor is held down by 4 - 9/16 hex bolts underneath the base plate and 2 bolts on the side. Is there an "easy" way to remove all 4 base plate bolts without disassembling all of the brackets? I've removed 3 of them but the last one does not seem accessible with the various tools that I have tried. It also has power steering so the PS bowl is in the way.
Though its been several years I seem to remember having the same issue. I think I ended up removing all the brackets. It turned out to be something I needed to do anyways since the Sanden didn't line up correctly for the belt and I had to fiddle with some spacers. If you bought a kit then you probably have all you need. I bought mine used and had to order an adapter from Classic Auto Air (or maybe it was Vintage) to get the compressor to mount correctly.
It looks like you're correct in removing all of the brackets. It will be a good opportunity to clean them up before installing them. Another question, I bought the optional idler that Ford offered to reduce belt slap a while back. Will the Sanden compressor still require that idler??
My car came with the idler pulley so I left it on, no problems and it allows me to tighten the belt properly. I also still use the stock size belt.
