21 - 38 of 38 Posts
· Registered
Change your spark plugs. Could it be that simple? YES.
· Registered
Here's what I know. After a successful initial startup on my new engine it wouldn't even start again. I messed with timing, I changed carbs, I did insanity stuff like checking firing order 100 times, on an engine that ran flawlessly for 30 minutes. I finally changed the sparkplugs and it fired right up. I guess I fouled the plugs on that initial run time. Residual oil from assembly? Blowby from not fully seated rings? Carb too rich? Timing wrong? Could be any if those. But new plugs curred months of insanity. Such a simple thing.
I'm letting you know just incase.
· Registered
Discussion Starter · #26 ·
Here's what I know. After a successful initial startup on my new engine it wouldn't even start again. I messed with timing, I changed carbs, I did insanity stuff like checking firing order 100 times, on an engine that ran flawlessly for 30 minutes. I finally changed the sparkplugs and it fired right up. I guess I fouled the plugs on that initial run time. Residual oil from assembly? Blowby from not fully seated rings? Carb too rich? Timing wrong? Could be any if those. But new plugs curred months of insanity. I'm letting you know just incase.
Oh I understand what you're saying. I did replace my plugs from the ones that were used during initial startup. Those were somewhat fouled due to an old carburetor I initially had on the motor.
· Registered
I agree sounds too lean in the idle circuit which could be caused by vacuum leak or misadjusted carb. Do you have another carb to try?
You could also start it and spray wd40 at various places on the engine to see if the idle changes.
· Registered
67 Mustang 351w
I did degree the cam to 4* advanced.
You may want to verify the cam doesn't already have a 4 degree advance ground into it; mine does. So in my case, lining up the dots gives me a 4 degree advance.
· Registered
Discussion Starter · #36 ·
I have an old 4160 Holley in the garage, it would need a rebuild but I can try it. I've tried spraying WD-40, carb cleaner, and propane gas to search for vacuum leaks.
21 - 38 of 38 Posts
