Research nets split results, so I post it again hoping for a clear cut answer. When using the Felpro intake gasket set (the ones with the blue stuff bonded to the gaskets), do you guys/girls recommend using gask-a-cinche, or installing them dry. I intend to use RTV on the ends (NO CORK HORROR STORIES HERE THANKS!). While I'm at it, for those of you running aluminum valve covers w/ Felpro cork gaskets...did you gask-a-cinche the gaskets to the valve covers? What about to the heads? Sorry for the lame questions, but it's better to be safe than sorry eh?
Shannon a.k.a. The ShanMan! /forums/images/icons/cool.gif
66' Vintage Burgundy C-code coupe
http://albums.photopoint.com/j/View?u=1571656&a=12306481&p=42935059&Sequence=2.jpg
Gone but never forgotten
Intake: Use RTV sealant around all water ports, and on the ends (toss the end corks like you said)
Head gasket: DO NOT use sealant
Valve cover: User descretion. I use none, but use have installed studs into my heads with chromed "trick looking" nuts on the top side. Makes installing my Edlebrock covers a piece of cake.
http://www.classic-mustang.net/john66/mustang/pics/66fsides2.jpg
You're right on the money Shannon. I use Gaskacinch around the water ports on both sides, and RTV on the end seals.
I would Gaskacinch the gaskets to the VC's like was said earlier. It can avoid a PITA when trying to remove the gaskets later if they're not sealed to the heads.
Hal
Love hard, drive fast, wear your seat belt.
PS, that's my 'bird...... My Mustang is too ugly to take pictures of yet........*G*.
http://www.teleport.com/~cosa/bird2.jpg
RTV around the water ports and for the ends of the intake. I use gasket cement on all valve cover to gaskets, makes removal of the valve covers at a later date much easier.
68 GT500
68 1/2 CJ Coupe
MCA# 18519
