hullo..hullo....
brought to you from the sunny skies of northern california..
where you can enjoy the sun as that is the only thing left affordable around here.
Got a question
Found a c-4 tranny...but its a 68.
will it fit into a 66 with no problem?
If not..what mods have to be done?
thanks..
john
Discussion Starter · #2 ·
Im not a tranny expert by any means... but im almost positive all c4's are the same and that you shouldnt have any problem with it
Absolutely no problem wit the tranny. Did this exact thing with my son's '66 years ago. The shifter wasn't a perfect fit if I remeber correctly, but it worked.-Doug
Doug-"Whether you think you can or think you cannot.....you're right!!" INDY-USA. GT/CS w/289-2v,PDB,A/C,PS,candyapple red,black top and interior,pertronix,chromeSS Wheels w/ GT centers, 215x14 BFG radial T/A's 3.55:1 open and KYB's
Moderatly Old Fart
Biggest difference is the D21 shift pattern instead of the 66 C4 Big dot for drive method.
The shifter problem may be because the trans may have come from a column shift car. I suspect they may be different. Bellhousings should be the same for all small block V8s.
Gene J
http://albums.photopoint.com/j/View?u=1584519&a=12058180&p=43615717.jpg
66 Coupe/66 Convert/84 GT Turbo/96 coupe
Gene's cars
