I installed the JMC hydraulic clutch system in my 65 mustang about 16 years ago. During a recent restoration i left the master cylinder off the car without fluid for a year and it has broken. The inside is covered with rust colored goo and it no longer pumps fluid. The piston does travel in the cylinder though.
I researched JMC and it appears they went out of business. I also located i believe the part they sourced to make the kit which is a CNC 711 master cylinder. But have found that CNC is also no longer in business.
Can anyone help me to find a replacement master cylinder or a rebuild kit? Or if any other brand kit will work with the additional holes i have punched in the firewall for the JMC kit? Should i just weld up the holes in the firewall and change to another kit? Any recommendation is helpful.
References:
Car specs provided for clearance issues:
References:
- 351 Windsor
- JBA shorty headers
- T5z Transmission
