Finally got the fomoco strip home.On closer inspection found small rubber **** on the strip where it runs in the outside groove of the moulding.Razored them off & ran sandpaper along the bottom of the strip where you could see it binding.
Coated both pieces with dishwashing detergent & while still in the car got it down to within an inch.Pulled the window & clamped it in the vice where I could pull from the bottom & in she went!Another pair of hands would make it a bit easier.
I'll go & get a repo replacement for the one I stuffed & have another go at it.
We can do the impossible around here,miracles take a bit longer"G".
Never go into a Battle of Wits Unarmed!
http://albums.photopoint.com/j/View?u=1589603&a=12101731&p=43846223.jpg
Regards From the Great South Land.
Excellent reply!!It's very hard to type when your giggling!"LOL"
Greg
Gone but never forgotten
Well, you certainly have a) more patience or b) better luck than me *LOL*. I was so f&*#^g frustrated by the time I had trashed the one strip, I just gave up. I tried everything but the dish detergent ... I'll give that a try if I ever have to do it again.
I tried WD-40, vaseline, sanding out the metal groove, pulling, pushing, sweating, cursing ... none of it worked *LOL*. By the time I was done, the new strip was WAY worse than the old strip, so I just put the old one back in! The weird part, is the first one, while a pain, did go in "fairly easily" (at least in comparison) and worked great. Mine were repros, though, so I thought THAT was the problem.
Thanks for the update, and I'm glad you got your's in!
