1 - 11 of 11 Posts
From the photos, it appears to be a member of the FE family (390, 410, 428?) and most likely has '68 or newer parts on it. The Cylinder heads do not appear to be 428 CObra Jet heads. Beyond that, the metal tag that appears to be sitting on the intake manifold might shed some light about the engine if the tag is the one installed at the factory. Not much else visible to provide evidence of what it is. If the block is a '68 or newer, it should have a partial VIN stamped into the flat pad at the back of the block just below the cylinder head.
A site such as the 428 Cobra Jet Registry has quite a bit of detail that might help you sort it out visually.
Possibly, More likely a 390.
Mustangtek has some info.
C7ME-A Block could be 390 or 428 Is there raised letter C on the rear face of the block? The letter would be scratched into the sand of the mold.
C8AE-A Intake is a 390
C8AE-J? or I. Is this the cylinder head? Listed as early 68 428 CobraJet. How many exhaust manifold bolt holes are there on each side?
See https://www.428cobrajet.org/id-block for figuring out if your block is a CobraJet 428. Surest way is to measure the bore.
Asm109 is correct the quickest way to determine if it is a 428 block is the check the rear bulkhead for a hand written "A" or "C" scratch prior to casting. If it does not have either then its almost certainly not a 428 block.
That C8AE-A intake was also used on the Q code (428) full size cars in '68.
The C8AE-I heads are pretty rare but nothing special they were used on all versions of the 390 for a short period in the fall of '67 ('68 model year).
The partial VIN stamping on the back of the block did not start until Jan 1st, 1968 which was halfway thru the '68 model year. Check the date code on the block and if it was cast after late November '67 it might have a partial VIN stamped into it. Sometimes these partial VIN's were stamped on the back of the head instead.
Ok the A cast may be a cobrajet or may not. Only the c cast will confirm cobrajet. Ford was cruel and made the FE line a bear to ID. Use that cobrajet ID link to ID. If you don't know what the cast C is look there. Or you post picture of the back of block (transmission face) and we could ID.
Its a 390
Agree with cj428mach. Intake is a 390 - 4V intake as denoted by the "S". Heads are likely C8AE-H (castings are not always perfect so check the other one) and either 8 or 14 bolt on the exhaust flange. If original to the Fairlane it would be 14 bolt same as Mustangs. CJ's would be C8OE and have 16 bolt flanges. With all that in mind it is likely a 390 block as well, but all of these motors have a story and are likely not as they were first built. As others have mentioned, the C or A scratch on the back bulkhead is a giveaway for a 428 block. Without it you almost certainly have a 390. You would need to pull the freeze plugs and look in the water jacket for a 428 stamping and/or measure the bore and stroke.
Not to say it isn't worth picking up. I would pull the valve covers and get the date codes off of both heads, check the block (below the oil filter adapter) and intake and post back. Look for something with possibly a 7 or 8, letter and number. For example, 7A15 would be January 15, 1967. Hopefully they are all within a couple weeks of each other. Having pieced together a date code correct 390 for my car there are plenty of people like me looking for the same to match up with my car build date.
Good luck and nice score!
Ford phased out the A scratch 428 blocks several months before the introduction of the 428CJ engine. The C scratch 428 blocks first appeared in the summer of 1967. The last documented A scratch block casting was in November of '67. In general (there are some exceptions) the A scratch blocks did not have the extra main reinforcing rib and the C scratch blocks did. I will not argue with anyone who says that a C scratch block is a "Cobrajet" block but the fact is that there were a lot of early Q code '68 full size Fords that were built with this exact same block.
1 - 11 of 11 Posts
