·Well, I think it's bad news. I just did a compression test on my 37k mile boss 351. The results: (1) 180: (2)95: (3) 175: (4) 175: (5) 170: (6) 175: (7) 100: (8) 160
My observations after owning this car for six months (and not driving it too much, as it's mostly disassembled).
* low on power. The cleveland has not impressed me in this car. Just doesn't pull strong like I thought a boss should
* no oil on the spark plugs (very minor if any), and not burning oil as far as I can tell
* good oil pressure
I was planning to pull the engine in a couple months to detail the engine compartment and detail the block, so I'll do whatever I have to get this thing running the way it's supposed to.
Also, a question. As three or four of my cylinders read around 175 (as my maximun compression reading), I would've thought my highest cylinder would've read over 200 psi as the boss has 11.7:1 compression?
Could a head gasket be causing these wacky readings? A couple of notes. I did this on a cold, cold engine with the throttle closed and all the spark plugs removed. The low cylinders I checked several times (as I was heartbroken) - and removed the screw-in tester and reinstalled it. Also, on the lowest cylinder, #2, I pulled the valve cover and checked the valve adjustment. It was fine (just like the other cylinders).
Maybe I've got a broken ring. I didn't try squirting any oil in the hole....maybe that's the next step. That or a leakdown test.
I would greatly appreciate any advice. Thanks and best regards.
* good oil pressure
