65 Convertible disc/drum setup ,just had new dual reservoir m/c and booster installed , new rotors and calipers and lines ,new wheel cylinders and shoes on the back.
Struggling with long peddle travel and soft stopping. Have bled several times and adjusted the rear brakes as much as my mechanic is comfortable with. It's better now but I'm still not thrilled with the stopping ability. I don't think its air in the lines because I can't pump the peddle up. I been following a couple of recent threads with great interest.
Should I be able to "lock" these brakes up ? right now that's not possible.
Wondering if I just need to get my head around the fact that it's an old car or is there a problem?
What are the details on the addition of the booster? What swap did you go with? Was the pin relocated on the pedal? This is an important step to adding a booster.
not sure which kit my mechanic used and I thought he told me 65-66 did not have an adjustable pin on the peddle ?
Mechanic has the car now so I cant take any pics
Not an adjustable rod, a relocated pin. The place where the rod mounts needs to be moved on the pedal arm itself. Find out what swap your mechanic used.
Power brakes (both factory and swap kits) move the location of the pin that the actuator rod mounts to on the pedal. So if you’re putting a booster on a car that came with manual brakes, this pin needs to be relocated.
I’m no engineer, so I can’t tell you all the why’s and wherefore’s, but it is necessary on all swap kits that I’ve ever seen. Perhaps there are exceptions, but not in my experience.
Just to add a little more info. When I bought the car it had Non Power front disc with the large bowl single reservoir.
The brakes were not functioning when I purchased the car and had been sitting for 5 years.
As much as the peddle travel concerns me , I'm more concerned about the lack of stopping power and not being able to "lock up" the brakes.
Power Brake Upgrade for a 1965/1966 Mustang with Front Disc Brakes This power brake upgrade uses a Fox body booster with a 1″ bore master cylinder for FRONT DISC brakes. The kit does require you to modify the pedal support and stock brake pedal. This kit can be used for manual (cars with clutch...
I just think there must be a physical problem if I can't lock the wheels up during a hard stop
Where the residual valve that I have read about located ? can you tell just by looking if I have one ?
Residual valve can be a separate part located somewhere on the rear line or built into the master.
I don’t know this for sure, but seeing as the residual valve is there to maintain a small amount of pressure to preload the brake shoes so that there is less delay between pedal and actual braking, I don’t think it would significantly impact overall braking power. Rather, it takes less pedal to begin actuation.
Would love to know if I’m wrong though if any hydraulics experts know better.
I do like the idea of checking the adjusters in the rear.
I had the exact same problem, then finally figured out I did not change the pin as already mentioned. It obviously puts the wrong angle on the rod into the master cylinder, hard to figure but it solved my problem.
The '65/'66 cars did not have different pedals for manual and power brakes. For power brake cars there was an adapter that went between the firewall and the booster that changed the ratio of the pedal for power brakes. You can see it in the photos of this kit.
So I need the adapter and also need to relocate the pin too ?
I'm thinking what ever kit I got probably had the adapter with it as most of the kits I see online have the adapter included.
We'll know more if you clear up what booster you have. Of course, the booster is not capable of improving braking. Boosters effect only pedal effort, not stopping. Of course, a malfunctioning booster can make things worse.
The OP keeps referring to lack of ability to lock the brakes. The ability to do this was standard equipment. The 200 I6-equipped Mustang, with 9" manual drum brakes, was capable of locking the wheels.
Thanks to everyone for all the great information!
I will try to find out more info tomorrow.
it's one of those thing where I don't want to tell my mechanic how to do his job when he is the "expert"
good info, but I don't think its a booster problem. It's a lack of pressure at the wheels that won't allow the brakes to lock up. So I'm leaning more to a m/c problem or the shaft between the booster and m/c.
Mechanic is supposed to be checking the pressures at the wheels today...
That should revile a lot.
ya it will reveal there's not enough pressure in the system which you already know since you can't lock up the brakes. Pushrod travel seems most likely or rear brake adjustment or air or some combination of 3 of those would be my guess. or bad MC but i think you said it's new.
Not to be a dick but I hope you're not paying much for that mechanic...
mechanic added a bushing at the pedal pin to help with travel and seems much better.
However still can't lockem up
Interesting that both reservoirs are the same size, most seem to have a smaller front reservoir.
That kit has the adapter that changes the pedal ratio. The video says it needs 18" of vacuum at idle to operate the booster. Does your engine make 18" of vacuum at idle?
The reservoir size has absolutely nothing to do with stopping power. The size of the piston has everything to do with stopping power and the specs say it has a 1" piston.
When you try to lock up the wheels are you standing on the pedal with everything you have or are you expecting the booster to do all of the work for you? Maybe your engine is not making enough vacuum for the booster to do it's job efficiently and you need to apply more leg effort.
Good point , and you may be right about the leg effort.
I haven't driven an old car on a few years !
@ BlakeTX I see we have the same manufacturer but a different kit
Wonder what the differences are as far as performance and application ?
I"m confused. You have linked the Master Power brake kit, while I have the Mustang Steve power brake kit. Everything in my setup, aside from some modifications to the pedal and support is a Ford part (booster and master).
I'm not familiar with the Master Power kit, and I must say, I've never seen a master cylinder that is supposed to work with all drum, all disc, or front disc/rear drum. That's a new one for me.
Forgot to mention: If there is any chance at all, as awhtx is saying, that maybe you're just not stomping on it hard enough, that would be my first test. Take it out somewhere where you have room, and stand on that pedal like your life depends on it. If you still can't get it to lock up, then we can keep trying to diagnose.
As a potentially separate issue, the suggestions about vacuum are solid too. But again, that's about pedal effort, not stopping power. Even if you disconnect the vacuum hose from the booster, your brakes should still perform, just with more effort.
Related Threads
Vintage Mustang Forums
4M posts
89.2K members
Since 2001
