K&N filters
960 Views 14 Replies 13 Participants Last post by  Guest
Are they worth it or is it all hype. I was thinking about using one for my cleveland in the Mach
1 - 15 of 15 Posts
hell, they never need replacement (only cleaning) and flow big air (a 14 by 3 inch k&n flows 900 cfm!!)
Hi whales,
I've been using K&N filters on my 240Z's for years and just recently put one on my 'stang. I can't vouche for any HP increases, or other hype you've read about but they certainly don't hurt either. The strongest selling point to me is that you're buying one filter and that will be it. You'll never have to replace it again. Clean it once in awhile sure...but that will be it.
Best Regards,
Landmissle
I think they are worth it. Unless you're SWMBO takes the car to the dealer for work and they give her a line of feces about it not meeting warranty specs and they charge her $37 to put in a $10 filter. Damn that pissed me off. I was in Italy, so I didn't know about it until it was too late.
K&N Filters do flow much more air and do a better job of keeping the dirt out. Very easy to service. Every vehicle I own has one.
Air filters won't increase HP unless you're replacing one that is stopped up. Other revelations;
Zmax with linkite is a rip-off
Traction bars won't stop tire spin
Fiberglass won't "fix" rust
Ceramic header coating is better than paint, but only lasts 2-3 years
Bowflex won't give you a "perfect" body by using it for 10 minutes, 3 days a week.
No Santa Claus..
I use them in all my street driven cars.I did have one on one of my Drag cars.(68 Cuda 340 auto,nitrous 10.90car)and it would slow the car down .3 but this combo needed to flow lots of air. Robert
I can't vouch for HP increase either, but they do keep all the crud that's in the air out of your engine better than a standard paper filter. (Sort of the technical definition of an air filter anyway.) You'll be stunned the first time you clean one and see all the 'stuff' coming out of it. Won't use anything else!
"Air filters won't increase HP unless you're replacing one that is stopped up"
To hear my youngest Brother-In-Law's friends (19-ish, import crowd wanna-be's) talk, a new muffler w/salad shooter end pipe, K&N filter and some R-Type badges and they've just picked up "Atleast 50 hp!" Now we know that most of that comes from the R-type badges! /forums/images/icons/smile.gif
SprintCC
Go with the Holley Powershot. A few bucks cheaper than a K&N and they flow about 100-200 more cfm.
June's Hot Rod magazine has an article on this topic comparing AFE, Holly, K&N, Purolator, and Rush.
Conclusion was not much on HP gain between them, but others filtered better.
After two years, I need to buy a new one. I didn't keep the reciept. =\
Too much gunk has built up that wont come off. A downside of having the filter right behind the hood scoop.
I used a cartridge element on my '87 Nissan Hardbody with little increase in HP. I did put a 360 cold air intake on my '95 Jimmy and did notice a little better throttle response.
As for the dirt, there are many arguments either way. Some say that - because the filter lets more air in - more dirt can get in the intake and mess up the engine. These same people swear by paper filters. Others argue that the particles are trapped by the oil in the filter element (This is sprayed on.) and catches any of these dangerous particles.
Here are some arguments in the google newsgroups. Since I am more familiar with the chevy trucks, I used that as the second example:
Mustang: http://groups.google.com/groups?hl=en&lr=&ie=UTF8&oe=UTF8&newwindow=1&frame=right&th=67b227ef201b0a4f&seekm=2899mt0v7mfp3vgpjra4eboi1vlbf6004l%404ax.com#link1
Chevy: http://groups.google.com/groups?hl=en&lr=&ie=UTF8&oe=UTF8&newwindow=1&threadm=EiID5.49189%24g6.19488734%40news2.rdc2.tx.home.com&rnum=1&prev=/groups%3Fnum%3D100%26hl%3Den%26lr%3D%26ie%3DUTF8%26oe%3DUTF8%26newwindow%3D1%26q%3DK%2526N%2Balt.trucks.chevy%26btnG%3DGoogle%2BSearch
Here's another on dealing directly with classic mustangs...
http://groups.google.com/groups?hl=en&lr=&ie=UTF8&oe=UTF8&newwindow=1&threadm=20010524205201.02564.00001185%40ng-fa1.aol.com&rnum=1&prev=/groups%3Fq%3Dmustang%2BK%2526N%2BFilters%2Bfactory%2Bresponse%2B%26ie%3DUTF8%26oe%3DUTF8%26hl%3Den%26btnG%3DGoogle%2BSearch
Oh, and one of my buddies who restores old Pontiac TransAm cars works at a place which does dyno testing software. He's tested his '96 Mustang and his '78 Firebird both with and without the K&N and swears he sees a numeric difference. I'll have to get in touch with him to see just what the numbers were.
KP
1 - 15 of 15 Posts
