The transmission install was done wit minimal issues. I was actually surprised at how easily it went, but Modern Driveline's instructions/videos and Andy Kruse's videos helped a lot.
The flywheel and clutch went on without any issues. I did have a question about the bellhousing cracks, which were answered here Bell Housing Cracks. Modern Driveline also got back and said not to worry about them.
Probably the only issue I had was installing the bracket for the hydraulic slave cylinder, and I did the same thing Andy Kruse did and installed it a bit too far into the bellhousing, but I was able to work one of the drilled holes just a little with a bit, and the bolts went in fine.
Stabbing the transmission took a bit of work, and the clutch fork came loose initially, but was easily reinstalled. Once I got the clutch fork centered and the transmission centered, it slid in without any problems..
This more or less concludes my engine / transmission work until I get it in the car. I am going to have to find a good location to store it in my garage because I am probably 6 mos. to a year out before I will get to put it in.
Next on the list is to look at the wiring. I will probably look at @Midlife and his refurbishment of the harness. I did receive the disc brake conversion from @CHOCK, but until I get the car back, there is not a lot I can do there. I am going to swing by the body shop tomorrow to check out their progress.
