I installed a new ignition switch in my 66 mustang. Now i cant get the key out when it is turned to the off position and it will not turn back to acc. position Any ideas?
67 mustang fastback, 70 351w t10 4 speed,64 falcon,170 3 on the tree.
What brand switch was it? I have ran into a few problems with some of the Wells ignition lock cylinders, I have much better luck with Standard ignition products,Wells is sold predominantly at Auto zone stores.
It is a scott drake ignition switch. I messed with it after work and still cant get my key out or turn it to acc.
No , they only go in the switch one way, was the cylinder turned back past a accessory when you slid the cylinder into the switch? Possibly just a bad cylinder, maybe one tumbler has fallen out, was your old cylinder bad? or broken?
This is the original tumbler in a new switch. the tumbler works fine when out of the switch. When it was in the old switch and turned to start it would not come back from the start position unless you turned it back like a broken spring or something.
