I had a good week last week. I got quite a few things done on the car:
I wonder if a bigger radiator is in order? Nah...
- Install 4" longer steering column from Ididit
- Replaced the 4.5-leaf springs from Canadian with 4-leaf from Mustangs Plus. The ride is much more supple now and the M+ springs are mid-eye on both ends, which keeps the pinion angle from changing in the process. The Canadian springs were only mid-eye on the front.
- Got the A/C mount from the machinist. It's not perfect, but it'll do for the first effort.
- Got the A/C compressor installed, hooked up and the system charged. The A/C works quite nicely.
- Adjusted the valves again. They were not loose anyway.
- Got the TCP motor mounts installed. Good thing too, as the A/C compressor has less than 1/2" of clearance between it and the TCP brace.
- Had the windshield replaced. The old one was original Carlite and looked like it had been sandblasted.
