That engine block was cast on May 4, 1967 (7E4). It is not original to the car whether it's a 64.5 or a 66.See If you can see the engine code and decode it.
Is this photo of my '66 parts car distracting? It's flat on the ground. The 2 rear VINs are stamped out near the edge of the fender aprons so that they are covered by the fenders. The forward driver's side VIN is stamped more towards the centerline of the car so that it is visible in the cutout area of the left fender flange. I have used white chalk and a red pencil to highlight the 3 VINs Ford stamped into the aprons.To me that picture is very very distracting why is it on it side 1st of all 2nd of all it's confusing to me doesn't make sense.
Which 2? The 2 rear ones I'll assume. So the 1 VIN that is visible with the fenders in place is missing. Did you check closely to see if the stamping has been filled with bondo? Or the metal with the VIN was cut out and a blank piece of metal was welded in it's place? If either of those 2 conditions exist you know the car has an illegal history.2 vin stamps on fenders
