·Guest
My '83 Ford van uses the same type of sliding switch found in the '67/68's (don't know about later than that), and has intermittent built into it. If you have a 67/68, I'm sure you could retrofit the sliding switch into the bezel and then hook up your wiring to the motor. While I don't know about all intermittent setups, many simply use a break-over capacitor setup, in which voltage has to build up to a certain point before it will trigger the motor. The switch itself is a variable resistor that will regulate the time between breakovers by limiting the amount of voltage that flows through it (and, therefore, making the cap take longer to reach the breakover point).
If my van ever gives up the ghost (actually, WHEN it does
I think I will probably do this retrofit myself.
Visit my repair page for Repair info, with pictures! http://home.dencity.com/mustangcub
