Anyone have better luck with one vendor over another.
NPD has 2 LCA's available, 1 with press in balljoint & 1 with riveted balljoint, both are more money than other vendors.
Have read posts that some vendors have better quality parts then others.
Also seems to be 2 versions of the UCA shaft kits, 1 with o-ring and another with a rubber sleeve.
Any input would be appreciated.
Thanks,
Don
Previously I had ordered a full suspension rebuild kit from another vendor and was displeased with the quality of the upper and lower control arms. With all the effort I am putting in I could not justify putting them on the car to save a few bucks: off to ebay they went.
I ultimately ordered the NPD "riveted" LCA assembly and was very pleased with the quality. The NPD "riveted" LCA I got was in fact a Scott Drake component... you can ask NPD who the vendor of the parts you are considering is.
Can't help with the upper shaft kit; I went with NPD upper arm replacements. Once again, a world of difference in terms of quality and service.
Good luck!
