I want to give an alternative report.
I went cheap and got great results. I did not want to have the "Jeep" headlight look as shown in your attachment (much too modern for the 66 vert), nor did I want the every-popular-Rice-Rocket halos -- but rather wanted something that looked a little more 60's appropriate.
I got these from EBay and they are fantastic. Less than $28 for the pair -- headlights plus LED bulbs.
Front Pair 7" Round Headlights & H4 LED Hi/Lo Beam Lamps for 1995 Geo Metro | eBay
Really.
Hard to believe, but here might be a case where high price is price gouging simply by touting "quality".
They fit right in without a problem and no modifications.
BTW, I HAVE ABSOLUTELY NO AFFILIATION WITH THE ITEM OR THE SELLER!!
I also installed the relay upgrade at the same time, although many say that it is not necessary due to the low pull from the LEDs. AGAIN, THE RELAY HARNESS IS NOT NECESSARY WITH THE LED CONVERSION!!
While I have had them since DEC19, I have not done any extensive night driving -- in fact, only minutes of use of the lights just to ensure that the pattern is good and that they were not blinding oncoming cars. No adjustments from the orientation of the original headlights was necessary.
They popped right in, but I did have to play around a little stuffing the wiring out of the way -- truly not even worth mentioning.
No problems with clearance in the buckets, even at the back of the lights
At the price differential, how could I go wrong?
I suppose longevity might also be one of the final determinants, BUT, so far, very good.
...but, once again, for the price...
I SAY AGAIN, FOR THE PRICE, HOW CAN YOU GO WRONG. 10 TIMES OVER!
I should also point out that there are blue-dot headlights available (ebay has for about $30), and I might have gotten them if I had seen them in time. HOWEVER, you would have to separately buy the LED bulbs - again very cheap and both headlights could be replaced for about $45.
Just presenting some alternatives to the ridiculously-priced LED lights.
Find many great new & used options and get the best deals for 7" 7x7 ROUND CHROME HOUSING GLASS PROJECTOR HEADLIGHTS+H4 BULBS+BLUE DOT LAMPS at the best online prices at eBay! Free shipping for many products!
www.ebay.com
Example LED H4 bulbs:
2X H7 LED Headlight Bulbs Kit High Low Beam 120W 225000LM Super Bright 6000K US | eBay
AGAIN, NO AFFILIATIONS WITH SELLERS OR PRODUCTS.
