1 - 11 of 11 Posts
What is your choice for spark plug brands???
I have to take motor mounts loose to change plugs in the 460. What does everyone recommend for Long Lasting plugs...
Ive never been able to tell a difference performance-wise between champions and autolites....
Folks who have used the Bosch platinums say they stay clean and last.
I have never had any luck with Champions. I worked on an old Allis tractor years ago, it was barely running and we changed the plugs with champions. It still ran rough, we checked the points, coil, carb, and was about to pull the head when we put two of the old plugs in the cylinders that were mis firing. It ran great. 2 of the 4 plugs weren't any good. A few weeks later I put plugs in my Goldwing and had 1 out of 4 bad. There will be no more Champions in anything I own...
I use Autolite or Motorcraft platinum plugs on my 460s; I'm not really sure what the difference between them is outside of either black or blue stripes on the porcelain.
I've found AC Delco has a wider variety of heat ranges for Ford engines. I usually run one or two stages cooler.
Me too, as much as I hate running the AC brand, they have the widest temp. coverage I have seen.
Autolites -- the side of the road is littered with Champions. Saw that when I was still riding Harleys. I use standard Autolites and replace 'em every year. Even in my lawn mower the Champions fail more quickly. If you have a hot ignition, don't bother with platinum or some other over priced plug; the hot spark will blow the precious metal off. It might be a pain to replace these things every year since you have a 460, but in my experience it is worth it.
Oh Now You Have Opened A Can Of Worms ! anyway I have always used autolite in the fords and champion in everything else. ::
Motorcrafts is what i run in all my BBF's for 429 inches to 606 inches. Good luck steve
1 - 11 of 11 Posts
