Pulled a 429 out with the factory brackets bolted to the exhaust manifolds. [Didn't pull trans at same time]. Used a chain hoist. If you don't have those, or an intake manifold to use a bracket on. Fabricate some out of flat 1/4" tool steel [bought online] bolt to exhaust on heads with either grade 8 sae, or 10.9 metric of appropriate size and length, whatever your engine uses. Drill holes in top of tool steel brackets to bolt chains to with hardened bolts, washers, nuts. Or you can do like I did, I saved the factory brackets from days gone by after putting headers on and used those after unbolting the headers to pull the 302/289 out. Never cared to pull transmission at same time. Easier to drop it out with a transmission jack. Just my preference with a standard.
