Hi guys,
I`m about to put in my new 5.0 HO engine which has GT-40 heads and a Offenhauser Aluminium intake.
I actually want to put it in with my C4 bolted together.
Do you think I can use the accessory holes to lift the engine without damaging the heads? :shrug:
Greetz from Germany,
Dan
Yes I have lifted plenty of motors using carb plates and they are smaller bolt hole sized than what you find on a the end of a head. just make sure it is threaded in fully
Look, engine, transmission, and K frame! With 4 little bolts threaded into the aluminum intake.
