Need some help i have headlights,tail lights and 1 brake light that are working. however the brake light that comes on is the passenger side rear and it lights up very faintly with the lights on you'd never know the difference, also i have no turn signals. what do i look for? please help guys.
Reads like you have as a minimum a grounding problem at some point(s) in the circutry. At least that is where I would begin the process of elimination. Before tackling that I would first ohm-out any bulb not lighting to be darn certain it is good to avoid chasing your tail unecessarily
you don't have much on your profile page and don't state your car year. if you have 2 emergency flashers (some don't have them) try them and then if they work swap them around and try flashers again. TSs and hazards are almost identical to TSs except flasher unit and wire from flasher to TS switch. PM me results and i can help you troubleshoot.
