Well, I think the new Shelby mustang coming next year will have a 5.4 engine with a supercharger a little bigger than the pick-up [lightning ] version. If you can do away with the shock towers somehow, then I think you might have a chance to make this a go?? Regards to the height of the engine, you could always cut a hole in the hood & put a scoop on it ?? Anyways, before you begin, know the measurents of the 5.4 then measure your engine area a dozen times,before you begin. I've done some things in the past like this & I should have measured 2 dozen times before i began. This is radical surgery, good luck.--S.
