How do these lights come out without taking the sail panel loose? How are they held in? Thanks.
Thanks Johnpro, I was hoping you would reply. I knew you had been working on your sail panels and probably knew how they mounted.
There is a small piece of spring steel on the bottom of the light that provides a little tension. You just need to push down slightly and pull out. The flat steel piece has a tendency to fall out.
