does anyone know if a 65-66 axle shaft will work in a lincoln versailles rear end? the left side is just a little twisted and i was curious if a mustang axle would replace it. thanks
If your talking the axle itself, I highly doubt it. But then again I have never tried it either. The disk rotor
center hole will most likely be too big, and the hat area
of the inside of the rotor might be too small for the axle flange to seat in.
The 65 axle will not fit. The Versailles rear axles are big bearing axles and I think there is some thing that may make them different due to the disk set up but I am nut sure on that one.
