Where would one best locate a fuel filter here?
The fuel pump is sized to feed the engine demands, not the type of carb or injection. A 300hp engine requires fuel flow for 300hp at the required pressure, regardless of the fuel delivery method.Curious....would the stock 65 fuel pump with the built in fuel filter be enough to feed a Weber setup?
it is, even at full throttle mile after mile. And that’s with the stock 5/16” lines.Curious....would the stock 65 fuel pump with the built in fuel filter be enough to feed a Weber setup? @zray ?
So we can advise @BlackStick to change out his fuel pump to the Carter M4009 with the integrated fuel filter for his Weber setup and call it good? Just might have to do a bit of modification to the pump itself to accept the AN fitting (which I have done on my car).it is, even at full throttle mile after mile. And that’s with the stock 5/16” lines.
I was all ready to put in 3/8” lines, etc, but it wasn’t needed
it worked very well for me.So we can advise @BlackStick to change out his fuel pump to the Carter M4009 with the integrated fuel filter for his Weber setup and call it good? Just might have to do a bit of modification to the pump itself to accept the AN fitting (which I have done on my car).
