1 - 9 of 9 Posts
There are two different types, one used a little end cap
and one didn't, which type do you need?
These are the two trim pieces that go at the front of the quarters on each side, not the rear two. I believe they are all the same?
Heres a couple picts. By caps do you mean the enlarged end to overlay the rear pieces?
On early models, it was a two piece design for each side. A long curved piece and a small square end cap. Ford used the two piece design into November 1964 (according to my unoffical research). On later models the small end cap was eliminated. This is why you were asked which type do you have.
The ones I am looking for is a late 65-66 style which has two long bent pieces on each side and a small square joiner in the rear centre? But all I need is the very front piece for both sides as in pict. (2 pieces total) Thanks John
The ones pictured are the later style that don't use the square end caps.
If you look at the end where it curves you see a screw hole, the
early ones didn't have that, the cap was a seperate piece that has a
screwhole and goes in that same area.
Discussion Starter #8
Thanks for the clarification. The later are what is needed if anyone can help? John
Discussion Starter #9
Drivers side needed! (Found the passenger side today)
1 - 9 of 9 Posts
