Does anyone have or know where to find the inline brake valve on the rear of a 67 fastback?
It's located in the brake line just before the hose to the axle on the left rear.The one on my car has been leaking and is getting worse.I've never seen them in any of the catalogs.Any help would be appriciated.
Which car is it Bob? I beleive the fitting you are talking about is the one on the end of the hose, between the hose and the steel line? If so, that is considered and sold as part of the hose and NPD has these hoses. The part number differs between the 390 and 427/428 cars.
This is what I found:
'67/'68 390 - PN 2282-2
'68 427/428 - PN 2282-4
Hope this points you in the right direction.
Rebuild yours if the leak is out the little holes in the side under the rubber ring. I have two disassembled in my shop. The piston inside has two rubber o-rings. There is also a small spring. Not a whole lot to them. No one sells a kit, but I'm sure the o-rings and the spring are available through McMaster-Carr.
