It seems that one of my cars PO installed a 65 289 and 3 speed, the car was a 289/C4. When this was done the clutch pedal did not align with the clutch access hole. As such they hacked the hole in four places and simply bent the metal out. I have hammered and dollied the metal back and welded the cuts. Leaving just the clutch hole behind.
Now, I am going to run a FMX Auto. This hole should not be needed. Is there a rubber plug I can use or should I make a steel one and weld the hole shut?
Any suggestions?
I could go cheap and use an electrical plug "push penny", Seems cheezy though.
T
One of the standard body plugs is used. Don't know the size. Look around your car and find one the same size. Order that.
On my donor car, also a 3 speed, there was still the knock out attached at one point. Although it was bent and a bit rusty I am going to install it in my firewall.
Not sure if it will be successful.
