Here's the original post as a refresher.Started the car to take it to the tranny doctor & reverse was back! But not for long.After a 1/2 hr drive, it was gone again!
Dropped the valve body & the low reverse band did adjust up tight,however the strut, opposite the adjusting nut, was hard up against the case.
Ian reckons there could be a problem with the L/Rev servo piston or stem,(Sound feasible?) but he did'nt have a cover seal & we could'nt immobilise the car.More next week......
Regards Greg
I just had my tranny rebuilt. Cost me $777 bucks but that included the torque converter, shift kit, new tranny mount and a new flex plate. Shifting is much more noticable but I understand that comes with the shift kit that was installed.
Should have done it years ago!
Did you guys try air testing the low-reverse band acutator? One of the two ports in the area of the actuator is for application, the other is for retraction...
The piston has a molded-on seal and IIRC, the whole unit is one piece so, unless it broke, I can't imagine what would've changed, other than the seal wearing out..
When reverse re-appeared, did you try manual low as a cross-check?
He did'nt try the air on the actuator,but when we get to it next week I'll suggest it.
When I had reverse I did have compression bracking in manual low & I just now went for a spin around the block & had all the gears.
On top of this, I now have a vacuum leak so we'll be kitting the Holley & finding the culprit before we get into the tranny!
I'll keep you posted,Pat.
BTW I checked the '69 Servo in the service manual & it shows the L/Rev servo can be dissasembled.Ian says all the pistons he's serviced are one piece units,similar to the intermediate servo's.Must be an Aussie thing!
Greg
This is exactly what happened to our car 2 weeks ago. The bands were gone and transmission ending up being rebuilt.
