My 289 has an issue getting off the line. I need a lot of clutch + revs to get it to roll. If I try to make tire oxide by dumping the clutch at some pretty high revs it boggs the motor down and will stall. The carb is a 4100 with the adjustments out 2 turns, timing is 6 btc. I did the timing chain, lifters and pushrods and everything seems tight, no leakes, vacuum or fluids. I am changing the fuel filter tonight (cheap stuff first) and I have the rebuild kit for the 4100. It also has duel exhaust so it is exhaling good. burning 94 octane, 190 thermostat.
:( What else could it be??
you need more initial timing, and probably more total timing 6 degrees is not enough most ford guys use the standard 10/30 just to get it running then after tuning and whatnot usually end up with 12-18 initial and 32-38 total. especially since youre running 94 octane you should be able to bump that up quite a bit without pinging. get a timing light and go turn that distributor, good thing its nice and easy to get to.
try bumping your timing up a little bit, try 10 or 12... and if it has a big, it could be a fuel delivery problem ( carb ) , or ignition problem .
I had the timing advanced and it was the same effect. thats why I started back at 6 btc
If this started when you installed a new timing chain is it possible that the cam is not properly syncronized with the crank and adding a bunch of retardation to your base timing? Did you degree the cam before installing the chain?
What rearend gear ratio do you have? If you have 2.79 you are going to have problems getting the car rolling. Or is this a new problem?
