I have a question that I have received several answers to. Racing motor guys say dont worry about it as long as you have 10 lb of pressure per 1000 rpm. others say jank the motor. I have a wild built 351 w. when I start the car the pressure is around 35 lbs at idle. As the car warms up it drops between 10-15 lbs at idle. when the rpms go up so does the pressure. The motor runs like a striped ape with no noise. It only has maybe 1500 to 2000 miles on the motor. Should I pull the motor and replace the bearings in the bottom half? I would like to get threw this summers cruises and rebuild it next winter? Well guys and gals let me know what you think!
Paul
Paul
