1 - 1 of 1 Posts
So i'm rebuilding my rear end, and last minute decided to go with a currie lsd.
I have packed one of the 2 pinion bearings with mobil shc greaseMobil Aviation Grease SHC 100 (4.4 lb Can). I plan on running redline gear oil with currie modifier.
Will the grease cause the clutch to slip??? I could clean it out with thinner but I may damage the seal.
I would think that that little amount would be f all in a big ship. I should of just lubed the bearing with gear oil, but pressed it together at work and didn't have any.
1 - 1 of 1 Posts
