Today I tore apart my center console looking to clean it up a bit and to replace the light for the shift indicator. I did some research and found this part:
http://www.mustangpartshouse.com/images/products/TRA-800_1.jpg
http://www.mustangpartshouse.com/newproducts.php
But they want 41 bucks for the part. Is there any way of opening this part up and replacing the bulb? If so, how do I do it and what is its part number for the bulb?
Don't have a number for the bulb but it should just pull out from the bottom,(wire end) including the socket with it. The bulb is just a push and twist to remove from the socket. The bulb is just a standard one, long glass as opposed to a round glass, single post/element.
