Has anyone here done a 428 with quad Webers? I have a barely used Jim Inglese setup for the engine I plan to build (for the car I plan to build) and am trying to figure a way to make it work with the shaker hood.... Thoughts?
Are they the upright IDA or the horizontal DCOE? If they are the IDA type, you could possibly build an air box that could connect with the outer portion of the shaker. But fitting all on a FE engine under the hood of a '65 would be quite an accomplishment .
Yah my 65 is built and done living in the garage.... This is a 69 R Code :) They are the IDA type but at the 10 degree cut manifold the Inglese uses so the stacks are more "centered".
