I guess I just need to take a break for awhile. Sorry for this long rant, but maybe it will help prevent the same things from happening to someone else. What follows is a fairly comprehensive list of every problem I've had since attempting my 390 engine rebuild, culminating in today's proverbial straw that has broken my back and spirit:
1. Engine pulled from car last fall, disassembled, taken to machine shop and everything seems fine. Spend lots of cash on new parts and machine work.
2. Get block back from machine shop and ready to begin reassembly. Final cleanup of engine and I notice a hole in one of my cylinder walls. Block back to machine shop to be sleeved.
3. Get block back and reassemble engine. Notice I put half of the pistons in backwards (notch on top of piston facing the wrong way). Fix that.
4. Finish reassembly and ready to put engine back into car. Bought FPA long tube headers. Wasted a whole day trying to get the engine and headers into the car.
5. Next day, finally get engine and headers into the car. Reassemble all accessories and wires. Spend hours just trying to get the car to start. Timing way off, but about dark get it running.
6. Begin putting miles on the engine. At about 600 miles, notice a strange, intermittant ticking sound. Shortly thereafter, bearing on water pump breaks, fan chunks into radiator. Ruined radiator and fan.
7. Two month fight with car store because I want refund for radiator and fan, not just water pump. Finally settle with them for $300. In the meantime, buy Griffin radiator (thanks Shaun) and spal fan.
8. Install radiator and fan. Wired direct to battery just so I could get the car home. By the time I get home, I've killed either the alternator or the voltage regulator. Also, notice coolant spewing from A/C condensation hose from the heater core.
9. Bypass heater core; buy new one from NPD to be installed before winter. Buy new alternator (powermaster 100). Install alternator. Spend day breaking 3 alternator belts before figuring out the problem (pulley not quite lined up and belt not tight enough).
10. TODAY: Happy as a clam, get up early to go for long drive so that I can keep putting miles on the new engine. Almost home when I hear a bad, bad noise, engine stumbles, at least one cylinder not firing right, immediately pull over and shut engine off. Discover that a shim that I'm using to hold on my oval Cobra air cleaner came loose and shot into the carb. Call AAA to get tow home.
11. Take carb off, pray that I can find shim with magnet. No luck. Take off intake; no shim. Take off passenger head; find shim in #4 cylinder. Top of my brand new piston is all mucked up with dings and scratches. Take break; successful in trying not to cry. The #4 piston is near the top and I don't have the energy right now to turn the engine over to see if I've also scored the cylinder wall. Even if I haven't, still need a new piston which requires engine removal and need to take a look at intake valve to see if it's hosed.
12. Cover engine with plastic and push car into garage. Who knows when I'll open the garage again.
I can't tell if it is me with the curse, or the car. Either way, I need to take a break. I've spent virtually every weekend for the past 6 months working on the car. To have this happen is just too much.
Sorry for the long rant. May take a break from VMF for awhile as well. Need to regain my spirit.
Chris
Chris
